Originally Posted by Old Tanker
Reversing, full lock on the turn, compression on the front spring... I don't think you can significantly "widen the stance" without a lift, trim, or rub. A wider stance makes the tire sweep across a longer arc.
Thank you, I appreciate the information. Definitely going to lift the 4Runner. Already have the fender tuck, but would do more if needed. I usually remove the mud flaps, so I don’t need those either. I just didn’t want to perform a BMC, but I guess it’s not the end of the world if you go through a quality company…..but there lies the issue in Illinois……not many great shops unfortunately.
