Originally Posted by southern_runner
Sorry, been on vacation. Yes, it's just like you said. When I turn on the A/C and set it to the upper vents, then I get air from the vents nearest the windows, none through the center vents, and air from the defrost vent.
Also I can't prove it but I feel like I'm getting heat near my feet...it's hotter in that area than I feel like it should be.
You shouldn't be getting any air hot or cold from the floor vents if it's stuck in defrost mode, also if the air coming out the other vents is cold then there no way you would be getting hot air anywhere else since the air comes/originates from the same place in the system and is directed to the various vents by the mode door.
Maybe you're just sensing a bit of heat radiating through the firewall/floor from the engine and or exhaust system.
