Originally Posted by AuSeeker
You shouldn't be getting any air hot or cold from the floor vents if it's stuck in defrost mode, also if the air coming out the other vents is cold then there no way you would be getting hot air anywhere else since the air comes/originates from the same place in the system and is directed to the various vents by the mode door.
Maybe you're just sensing a bit of heat radiating through the firewall/floor from the engine and or exhaust system.
That's what I was thinking, because the air is cold that comes from vents and defrost. There is definitely more heat coming through than I expected, but I was towing so she was working harder than usual.
