If it's not gear oil it's probably valve cover gaskets or the oil cooler on the driver side of the engine block. Both fairly common places for engine oil to leak on these.
If it's gear oil you may have a bad seal on one of your front diff CV outputs.
If it's not dripping on the driveway it shouldn't be loosing fluid at an extreme rate you can drive it and monitor, checking along the way.
2008 Toyota 4Runner Limited 4x4 - Salsa Red, DD, Mostly Stock, 89k miles
2001 Toyota 4Runner SR5 4x4 - Not Stock, Lifted, Armored, 291k miles
1987 Toyota Supra N/A - Stock, 2nd Owner, 92k miles
