Originally Posted by MacRendar
I am very surprised that you're still doing this manually. It's incredibly easy and cheap to monitor the exact temperature directly using any Windows/Android/Apple device with WiFi capability and a free app with this super cheap obd reader off Amazon. Works great, and doesn't trigger a zero point calibration on our 4th gens like some scan tools do.
Amazon.com: Veepeak Mini WiFi OBD2 Scanner for iOS and Android, Car OBD II Check Engine Light Diagnostic Code Reader Scan Tool Supports Torque Pro, OBD Fusion, Car Scanner App: Automotive
This is the exact one I have. I had to try a few apps to find one that worked right with the truck and unlocked all the sensors. on Android, the Car Scanner app using the setting Toyota - "OBD-II / EOBD K-Line/KWP + extra sensors".
I keep the dongle in my glove box, and have thrown it on there to have the wife connect and check my trans temp after long drives and hauls up inclines. I've never seen it rise above 175F, even after hauling ass up a mountain at 55 for 10 minutes in 95 degree weather.
Yep I've got a bluetooth one to use with torque pro and also an ultragauge, but I guess I like doing it the archaic way lol. I mostly brought it up because I see a lot of people just drain out x amount and put x amount back in without doing the level check, which could be over or underfilled if the original level wasn't correct
Do you have the v8 with the trans cooler? going up big hills, my v6 without cooler would be in the 195-205° range in 90ish° ambient so I added a cooler
