Originally Posted by BarberJoeJr
Update 7/28/21
Finally got around to doing some stuff to my 2021 Nightshade.
Tinted the windows (including the front windshield), removed the factory roof rack, lift and larger tires.
Lift is a Cornfed 2/1 lift and tires are 275/55/20 Nitto Ridge Grapplers on the stock Nightshade wheels.
No rubbing. No issues what so ever. First two pics are of the stock tires with the lift, then with the Nitto's..
This truck looks fanatic.
I'm in the process of ordering a black nightshade as well.
My plan is to go with the rough country spacer lift:
2in Suspension Lift Kit for 10-19 Toyota 4-Runner 4wd X-REAS Models [767] | Rough Country
The rough country kit has the stock extensions for the x-reas system. Did the Cornfed kit come with those?
I was also considering a set of 1.25 wheel spacers to slightly widen the stance on the stock wheels with some - 265/60r20 Toyo Open Country A/T III Tires. I don't want the tires to extend beyond the top of the fender, but a little poke never hurt. Lol
I noticed you went with a set of 275/55r20. Did the tire shop give you any push back on the 275s potentially rubbing even though you've discovered that they don't rub? Id' like to fill the wheel well with the wider tire as well.
