Now we will start seeing a lot more building and less tearing apart.
Today as I mentioned last week we started on the rear axle. All parts arrived yesterday so mounting the rear axle is immanent.
We didn't want to mount the upper links so high up but that's what gave us the best results. It will be braced and be plenty strong. We have measured and checked and measured again and should have no interference with the floor under full compression but it will be close.
The following items were accomplished:
1. Welded truss to rear axle
2. Mounted and welded the pinion tie in guard
2. Mounted lower link tabs
3. Mounted half of the upper link tabs
4. Welded sliders to frame
5. Tacked the lower link tabs to frame
6. Upper link tabs welded together and will be tacked to frame first thing in morning
Tomorrow rear axle will be mounted with 4 links and then check all clearances, work on coilovers, and finish any cutting required.
