Originally Posted by Skulking
When I replaced my steering rack, we initially tried to remove that fitting on the car and failed. Even using a flare nut wrench, it rounded over. We disconnected the soft line and pulled the rack with that fitting still on. With the old rack on the ground with more room to work, we clamped a set of vice grips on the nut, heated around the outside of the fitting with a small propane torch, and then hit the vice grips with a 4 pound sledge and eventually broke it free. Once that was done, one of my friends reshaped the nut and we put it on the new rack and installed it. The bottom line is that even if the rack and fittings are original, that fitting is a pain to remove, and if I ever need to do a rack again I plan on buying a new fitting rather than dealing with removing it again.
Wow that sounds just as involved as mine will become. Thanks for the info and will see what happens!
