View Single Post
Old 08-07-2021, 12:55 PM
Greydog's Avatar
Greydog Greydog is offline
Greydog is on a distinguished road
Greydog's Avatar
I have that as well, basically since new. It was a step down from my 300k 4th gen for sure, on a new truck.
Toyota May say it’s normal, as in most do it, but it’s caused by movement of parts that should not move in that way.
I’ve replaced inner and outer tie rods, rebuilt the UCAs, checked LCA, and wheel bearings, and sway bar components.
It’s none of those, it’s in the steering.
Next is to look at the interior steering column ujoint and the lower rag joint. I dont really thinks it’s those, the sound and feel seem to come front the exterior side of the firewall. But I’ll try to rule those out.
This gets us to the rack or the lower intermediate shaft components.
So also of note, nearly every bolt I’ve turned was barely minimum torque from the factory/new, so perhaps there is just something loose in that system.
I’ll report back.
- Mark
2019 TRD OffRoad - Fox w/Resi, 650lb Springs, JBA HD UCA, T12 Rear Springs w/DS 5mm Spacer, Odyssey 34R-PC1500T AGM w/Diode Upgrade and CTEK Monitor, NOCO battery charger wired to external port for shore power, Rago Hidden Winch Plate, Comeup Seal 9.5 RSI, RCI Sliders/ Skids, 285/70-17 Cooper AT3 XLT on Fuel Rims, Various LED upgrades, OE Engine Heater w/External Port, XenonDepot Low Beam HID & LED 3k Fogs, ScanGauge, Midland GMRS, Accessory Mount for iPad, mike and Inreach, iKamper Mini 3.0, Custom Kitchen/Cargo system, ARB 50Q, Goose Gear dual drawer, Wilco Solo Tire/Hilift/RotoPax Carrier.
Greydog is offline   Reply With QuoteReply With Quote
