View Single Post
Old 08-08-2021, 05:46 PM
Yardrunner Yardrunner is offline
Yardrunner is on a distinguished road
Normally turning will highlight a bad wheel bearing. Loading side to side. Where accel and decel will highlight DS, transfercase, trans rear end issue. Have you tried pulling the lift out? A 2 inch lift should not make the pinion angle that bad even tho you said it was corrected. . But I know lifts can make issues that where hardly noticable before alot worse. It almost sounds like extreme axle wrap. But that's about impossible. Does yours use a carrier bearing? Mines 4wd and I've honestly never looked at a 2wd.
98 4x4. 3.4 auto. 3inch spacer lift. 285/70r17s. 274k
Yardrunner is offline   Reply With QuoteReply With Quote
