Originally Posted by Bad Luck
That's great that you found your culprit! Regarding pinion angle, since you have a 2wd your rear pinion should be parallel to the transmission output and not pointing up towards the transmission output. Make sure you got 2wd rear upper control arms. 2wd and 4wd rear upper control arms are different lengths in order to change the pinion angle.
Hmm, I never thought of that. I used what I believe to be 4wd rear UCA’s. That would be why it made the symptoms a lot worse. I guess the control arms would need to be shorter than stock rather than longer which is what these are.
Originally Posted by Yardrunner
I had a duramax that I replaced the rear UJ in because of a shake. Next day same problem. UJ is loose again. Turned out the yoke or whatever you wanna call it was worn out. New yoke no more shake! So you make check that with the new joints. Even cheapo ones should last a little while. Glad you found it tho
Its funny you mention that, because I can’t tell if maybe the caps on the UJ aren’t the right size or if its like what you said, but I swear I saw the cap move around in the yoke a little bit, and as I think back to it I remember those caps sliding in a little too well, I originally thought it was because we had put them in the freezer.
Originally Posted by 4rFrog
Been through this, it's 100% pinion angle, you need adjustable rear links.
I had my drive shaft completely rebuilt and balanced, didn't help.
Balanced my tires on Hunter road force machine, didn't help.
Finally replaced upper and lower rear control arms, adjustable on both. Lined up rear pinion angle with drive shaft to with 1 degrees. Now it can go up to 100 MPH and it's smooth as silk.
Search - Toyota Double Cardan Drive Shaft pinion angle
https://www.triketalk.com/forum/atta...1&d=1487805932
I guess I don’t know enough about driveline geometry evidently. I will be trying 2 things next before I bite the bullet on that one. 1) put in new, reliable UJ’s from Moog, and 2) get an aftermarket DS from those Texas Driveshaft Specialist guys, I don’t care much for the OEM driveshaft, and if the yokes are worn out then it doesn’t matter how many UJ’s I put in and times I adjust the pinion angle. All else fails, Any aftermarket 2wd control arms you would recommend?
