View Single Post
Old 08-12-2021, 04:52 PM
DoctorPopcorn's Avatar
DoctorPopcorn DoctorPopcorn is offline
Real Name: Tyler
DoctorPopcorn is on a distinguished road
Real Name: Tyler
Is there any chance this could be the oil pressure sensor leaking? I had a good leak on my '05 when I bought it last year, and the dealer even noted it was the oil pressure sensor when they were doing the timing belt and water pump.
I changed it with an O'Reilly brand part out of haste, but I'd do OEM if I could go back. It was pretty easy to get to, just behind the filter, but you need a deep 22mm, I think?. As always, my biggest challenge was unclipping the plug connection. I still have another oil leak somewhere, looks like the driver valve cover, but I don't lose a noticeable amount between OCs. I tightened my VCGs bolts with a 1/4 ratchet as some weren't even finger-tight.
It's funny, too, because I had just changed the oil pressure sensor on my '98 and it was the main cause for me losing almost a quart every 1-2 weeks. Fixed my issue.
'98 Limited 4X4 320K (summer truck): OME/5100 lift, LT235/85/16 AT3W WPs, supporting mods, many trails, on 3rd rear diff. Rust.
'05 V8 Sport 4WD 250K (DD, was hoping for pavement princess, turned out to be a work horse): IronMan 4X4 Nitro Gas Stage 2: 2.5" 0-110 lb front, 3" 440-880 lb rear. Sway bar(s). LT255/80/17 Falken AT3Ws. URD Y pipe, Slyfox75 AIP Bypass. Also rust.
DoctorPopcorn is offline   Reply With QuoteReply With Quote
