Originally Posted by jaymart1983
1) For those that have installed this, does your temperature dial change the degrees on the little HVAC popup display? When I change the vent or a/c or recirculation setting, the pop up HVAC display shows the setting changes but the temperature degrees stay at 75.
this is how mine behaves I assume because i just have the basic climate control so there is probably no temp setting for it to read. maybe it shows the temps if you have auto climate control?
