Originally Posted by P1garcia
Just an update for anyone having a similar issue. After chasing this problem, replacing the cabin temperature sensor and the blend door servo. My next checklist item was the ac amplifier. I took my dash apart to check the connections and part number. I also followed the air temp sensor wiring from the sensor to the ac amplifier and found one of the wires had snapped off pretty far along.
Low and behold I reconnected it and problem solved.
The cabin air temperature sensor is on the driver side, right? Where is the ac amplifier located? Did you have to completely disassemble the center console (like you were changing the stereo head unit)?
I have an 06 with misbehaving air conditioning. If swapping the bottom air-mix servo doesn't fix the problem, maybe I'll take a look at the ac amplifier...
