Originally Posted by lewdog998
Did you test the lights first before mounting. Touch the bare wires to battery terminal. I always test things like this prior to installation. There could be a defect.
Second...did you check if there was power at the switch terminal where you have the lights wired to? Assuming you have a multimeter.
I have the same auxbeam switch and it works great.
I did, all the lights worked before I put them on.
Question, when you ran your wires to your auxbeam, did you leave the relay that the harness came with? I was reading that the box has a relay in it.
