View Single Post
Old 08-20-2021, 12:03 PM
kcdehart's Avatar
kcdehart kcdehart is offline
Real Name: Kevin
kcdehart is a jewel in the rough kcdehart is a jewel in the rough kcdehart is a jewel in the rough kcdehart is a jewel in the rough
kcdehart's Avatar
Real Name: Kevin
Recently added:
  • An interior rear hatch open button. Super easy process following this guide: Interior Rear Hatch release Button - Toyota 4Runner Forum - Largest 4Runner Forum
    Just bought a small momentary switch, soldered some longer wires onto it, and then spliced it into the purple with white stripe and the light green with red stripe wires on the rear door ECU. I recommend disconnecting the battery before disconnecting the plugs on that ECU. Otherwise, the rear door won't work, and you'll freak out like I did until you unplug the battery as a last ditch attempt to reset it
    When adding the switch, make sure it's small enough that it clears the metal behind the plastic cover panel. Also make sure you don't drill a hole in a spot where there's no clearance behind it..............yeah, made that mistake.......measure twice, cut once...
    I also recommend adding a cover of some sort so that you don't accidentally hit it when the vehicle's unlocked.
  • A sleeping platform that folds up so that the rear seats can still be used (bought from a friend for $100)
  • Napa awning! It's proven to be amazing for keeping cool at trackdays.
'04 4Runner - Build Thread | '05 CBR 600RR & 1000RR - The slow vehicles ;)
kcdehart is offline   Reply With QuoteReply With Quote
