Notices
View Single Post
Old 08-21-2021, 04:29 PM
18RunnerOR's Avatar
18RunnerOR 18RunnerOR is offline
18RunnerOR is on a distinguished road
18RunnerOR's Avatar
FS:5th gen 2018 4Runner TRD Off-road Premium 12K miles $62,000 Orange County, CA
*price drop*
This is my dream vehicle that is literally a one of a kind custom build. The only reason that I’m selling this is to buy the house I’m living in. The vehicle is fully paid off and I have the title in hand. Here’s the list…
From the factory -
-4 wheel drive with push button rear locker, crawl control and KDSS
-Black leather with red stitching and carbon fiber interior package
-Ultra white exterior
-10 year/100,000 Platinum bumper to bumper TRANSFERRABLE warranty
-Paint protection plan
The custom stuff-
-King 2.5 adjustable shocks all the way around
-DuroBump bump stops
-Camburg 1.25 Uniball Upper Control Arms
-285/70R17 General ATX (also comes with a mounted, full size spare and another mounted spare)
-KMC XD 133 Fusion Satin Gray rims (I also have the some with the mounted spares and one other still in the box)
-Body mount chop with cleanly welded end caps to fit tires without rubbing
-20 Degree CaliRaised sliders with kickouts and Line-X grip coating. Bolted to the frame
-Nitro 4.88:1 gear kit (my favorite/most worthwhile upgrade that I did)
-Gobi stealth roof rack with ladder with custom mounts on rack for hi-lift jack and accessories
-TRD aluminum front skid plate with custom hand painted lettering (not the stickers)
-Rig’d Swing Arm hitch mount that holds a full size spare. It also has a fold out table and a slide out wood cutting board along with an interchangeable composite cutting board that’s easily cleanable and won’t be subjected to road soot. Also has a hitch lock and wiring for license plate lighting.
-Ceramic tint all the way around including the clear front windshield
-One of a kind, custom black powder coated GPS dash mount that holds an iPad and GPS device for off-road navigation
-White LED interior lighting from front to back
-Weather Tech floor mats including the rear cargo area
-Custom, one of a kind (2) battery system with all MARINE GRADE wiring. No expense was spared! Each wire is individually secured for easy modifications or maintenance
-Odyssey 34-PC1500T second battery
-(2) BlueSea Marine fuse blocks, one for each battery. I ran extra wire for easy future hookups off of the secondary battery which is great for camping upgrades. Includes a Switch Breaker on the primary battery for protection and never need to buy the main fuse again. Also handy to manually “pop” when doing electrical upgrades off of the fuse box!I was using mine second battery to run a Dometic CFX75DZW and camping lights. Also great for charging phones.
-RedArc BCDC 1225D 25amp dual battery charger and management system that includes an active solar hookup
for use while camping or other adventures. I WILL include the Renogy 100watt Eclipse foldable panel and case and 25’ solar extension cord to park in the shade and still charge in the sun. Anderson plug hookups
-Installed a custom BlueSea charging panel in the front dash that is ran off of the second battery. Charge your phone or accessories up front while the vehicle is OFF without the worries of draining the primary battery
-Installed a custom BlueSea charging station on the passenger side of the cargo area in the back. Great to run a refrigerator or other accessories while you drive or camp. Wiring run from the secondary battery that can be charged from the solar panel while being used! No need to worry about draining the primary battery (though I don’t recommend fully running it down too often)
-Switched out most cigarette charging ports for USB charging stations that include LED voltmeters for the front AND rear charging stations
-Installed a Cobra 75WX ST that is hidden in the center console and is easily accessible when needed! Ran a coax out of the rear drivers tail light and properly grounded to the Gobi rack up top for great range. Installed a quick release antenna mount and comes with a 2’ and 4’ Firestick antennas.
-Off-road exterior lighting
-30” CaliRaised clear LED grille light bar
-40” CaliRaised amber LED roof rack light bar. I currently have it removed because it’s noisy when on the freeway and not necessary for street conditions. It reinstalls with only 2 bolts and one quick connect plug and takes about 5 minutes.
-(2) 6” CaliRaised clear LED light bars installed at the rear on the rack
-(1) 4” CaliRaised amber LED light pod (chase light) on the rack
I hit the max picture limit so please inquire to see the rest
*the only modification that I was looking to complete was to relocate the backup camera. Currently the spare tire and fold down table block the view. I’ve seen kits for a few hundred dollars
FS:5th gen 2018 4Runner TRD Off-road Premium  12K miles  ,000 Orange County, CA-a98b5c4f-c835-4211-82c9-741dc8d4fdd0-jpg  FS:5th gen 2018 4Runner TRD Off-road Premium  12K miles  ,000 Orange County, CA-d3df9750-4811-49a1-bb03-40ff33c665bf-jpeg  FS:5th gen 2018 4Runner TRD Off-road Premium  12K miles  ,000 Orange County, CA-27f8c9b9-848b-43d3-83bd-04550f78a141-jpeg  FS:5th gen 2018 4Runner TRD Off-road Premium  12K miles  ,000 Orange County, CA-6aedeb9f-a4d9-4c68-97dd-2c1d11021a0f-jpg  FS:5th gen 2018 4Runner TRD Off-road Premium  12K miles  ,000 Orange County, CA-220fa6d5-10eb-47da-bbd3-6240456520b5-jpeg  FS:5th gen 2018 4Runner TRD Off-road Premium  12K miles  ,000 Orange County, CA-12b3f138-09ef-4788-9d95-a345b2acb9e2-jpeg  FS:5th gen 2018 4Runner TRD Off-road Premium  12K miles  ,000 Orange County, CA-810a259f-8be7-41c9-967d-936ec7129dc4-jpeg  FS:5th gen 2018 4Runner TRD Off-road Premium  12K miles  ,000 Orange County, CA-d21049cd-aec9-4210-b037-110e7d210780-jpeg
Last edited by 18RunnerOR; 09-05-2021 at 01:15 AM. Reason: Hoping to create more interest
18RunnerOR is offline   Reply With QuoteReply With Quote
