Originally Posted by YOTARUNNERPRO
How stable is the box using the Sherpa mounts? Is there any front to back or side to side play where the corners can lift up?
you can get the case to sit snug on the cross bars but the case does shift side to side a little. That can be remedied by placing some rubber gasket material in between the mount and the slot the mount slides into
