Originally Posted by phattyduck
The OEM 2WD u-joints are non-serviceable (no grease zerks). Aftermarket joints will most likely have zerks.
That said, pumping it full of grease probably won't fix a bad joint for long - but it is useful for checking if the joint is the problem (pump it up, vibes go away for 100 miles - that's your culprit).
Well, the new universal sure is smooth, until you install it and drive it, and that shake is still in the truck despite the joints all working to spec. So I guess her driveshaft liner has given up? Any way to check that or simply replace and see?
