Best Shock / Spring combo for washboard roads. Not looking to lift
I’ve also done up to 60 mph on pave at 20-23 by the time it’s warmed up many many times. I try to stay under 55 in that case. Tires don’t even get hot. Obviously it’s not ideal and yes you “should” air up. It’s gets super loud on my Kanatis and yes it does roll hard. But for the brief 5-15 mile jaunt it’s not an issue during a day of wheeling.
28psi cold is very conservative to say the least. . Why even air down would be my thought. I think what’s important is go at the speed of your understanding here. If your really worried start at 25. Hell I’ve done 12.5psi in Moab before…. 18psi is a really nice all around pressure for a 10pr 265-75/16 3ply sidewall in my experience of trying all kinds of pressures.
For what it’s worth, I run 40 psi street and 18lbs that warms up to 20-22. Staun deflators are awesome. I also have an arb deflator. 5 people and gear always. 4.30 axles.
99’ Black “Highlander” sport, oak, 5VZ auto, 4.30 axle, e-lock, 265/75 Grabber X3,, Bilstein 6112 (2”) front 5160 rear shocks, OME 2906 springs, Durobumps, 4x Inovations front middle rear skid plates, 4XI square TRD tube sliders, lil skips tank skid, lotus dev RCA skids, overland custom sway bar links, Amp’d hidden winch, warn Vr Evo 10s
