Originally Posted by CJmixer99
Is this something that needs to be done ASAP? I called the Toyota dealership, and they confirmed the LBJ recall was done in 2009. The repair shop inspected the LCA and said the bushing were worn…
LBJ should be done ASAP as that’s a common fail on these parts. I’ve never really heard of LCA’s failing but the bushings are a common replacement item. Most people go with white line poly bushings because they are cheaper than OEM
