Originally Posted by Bad Luck
The only thing that cable controls is line pressure in the transmission which determines how firm or soft your shifts are and will also increase line pressure as throttle position increases. If it's too tight it will give you very firm and hard shifts even at lower throttle. Try loosening it an 1/8" and seeing if that changes anything.
Okay. Will do. I just read through the factory service manual and found the transmission testing parts and will do all of those as instructed and see what I can find out.
