I thought once one shock goes in the system, all system has to be replaced? no?
Originally Posted by spartacus
Good mechanic just replace the one that is leaking with oem if you like the ride. If you want to upgrade or lift then it's a matzo ball. you can get a set of 5100 pretty cheap from a bunch of vendors on line.
Bilstein 5100 Complete Set | 5th Gen 4Runner | FJ.
edit if you have the rear sag then get new rear springs. if you have the nose dive when braking get new fronts.
