View Single Post
Old 09-03-2021, 04:49 PM
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Originally Posted by Skulking View Post
I was under my 4Runner last night, and discovered that both of my front sway bar end links have snapped. The last time I was working in that area was last December when I replaced my shocks, and they were fine then. I don't do any offroading, so I'm not sure what happened to snap both of them. I'm at stock height, but I do have poly bushings on my sway bar, and had them on the end links as well. Is there anything I should be looking for that might have caused this to happen and should be addressed, or should I just chalk this up to cheap parts store end links?
With the front sway bar links disconnected (or the broken ones still on) how hard is it to rotate the sway bar? If the sway bar is too hard to rotate that could be what broke both your end links. If it is really stiff I would suspect the sway bar bushings are too small for the bar.
