Originally Posted by 1000MPH
Is there a better thread on replacing KDSS sway bar bushings?
I’ve seen a couple with this one giving some instructions.
how hard is it to replace sway bar bushing kdss?
Looks like the only thing to be careful with is the KDSS piston.
As long as the bar doesn’t go boing when I remove the bolts I think I’ll be comfortable.
KDSS Front Sway Bar Bushings
FRONT STABILIZER BAR, LEFT; FRONT STABILIZER BAR, RIGHT.
4881560320 MSRP $ 21.58 qty: 2
FRONT STABILIZER LINK, LEFT; FRONT STABILIZER LINK, RIGHT.
4884960041 MSRP $19.16 qty: 2
all it will do is fully extend at a slow predicable rate. you can hold it up with a jack or a strap. its just hydraulic pressure
