View Single Post
Old 09-04-2021, 09:39 PM
Syr4RinNC's Avatar
Syr4RinNC's Avatar
So the biggest problem is that you can’t get a socket to stay on?
You may want to try like a stripped head bolt remover - they have sets you can get for $10 or so
Otherwise could try seeing you can hammer on a 7/16 socket or 11 mm socket
Once you get the socket on again go gently tighten loosen etc otherwise you may break the head off and you’ll have to drill anyhow
You can also see if you can jiggle the bracket under the bolt back and forth to see if it’ll loosen anything
Good luck. If you’re on Facebook consider joining the Carolina off road 4r group - lots of members and can likely find someone to help if needed
