Originally Posted by Saker
Then you change out P rated tires for LT or non P rated tires, the load rating is different so you can throw the placard on the door column out the window as far as this psi inflation guidelines.
Personally I run 44 psi in my BFG All-Terrain T/A KO2 to meet my load needs.
This. If you went with E-loads then your pressure needs to go up to around 44. There's a link on multiple threads here that explains/does the correct psi for changing load and/or size.
