Originally Posted by carlodonz
Thanks a lot for this document
@ DougEFresh2
I have a question on the front differential fluid check. The DIY video you linked is very helpful but I was wondering if it's recommended to change the plug gaskets like that person does? Or you listed the part number just in case? Thanks!!
That's a good question, I suppose I could have made that more clear. So basically, just because I have listed a part in this guide, does NOT mean that you have to replace it.
This might not be the best practice, but I have listed every part for all of the main components that are
detached at
any point during maintenance.
I have also listed parts in which the torque can be verified without too much trouble and any part that has a limited lifespan that's associated with one or more of the main maintenance components.
I feel this was a good decision because anything that is removed from the vehicle for maintenance has the chance of being damaged or getting lost.
As far as gaskets go, rubber gaskets, like O-rings can be reused one time as long as they're properly lubricated and changed at the recommended intervals, but the metal, crush washers should really be replaced any time that bolt and washer are removed.
2016 SR5, electronic dial actuated, part-time 4WD
2016-2019 service manual:
https://www.toyota-4runner.org/5th-g...l-rm27f0u.html
