Originally Posted by 4RunnerRPT1
Does anyone know how difficult it is to remove the factory grille?
Just watch out for the hood release mounting clip. If you're not careful you'll snap the small plastic clip.
Otherwise the nuts might be rusted on there and you'll snap the bolt off at the end if you use too much torque to remove them. If you're replacing the grill, then it doesn't matter since they should have their own mounting bolts attached.
