Originally Posted by hawkcharmer
Thanks for this information. but how does one connect the green wire? Do I splice it in to a existing wire on the right side, use t-tap, butt connector? Not sure how this is done.
Any feedback its greatly appreciated. Thank you
Put a volt meter on it and make sure it's the correct wire, then splice it in to the existing wire coming from the front IE1 conector. I prefer soldering but you can use what ever you prefer. Make sure the ground is hooked up before you test it.
Edit: I'll second what
Patty
duck said.
