Originally Posted by Turfboy
Just forked out for the URD supercharger and was thinking about the CSF radiator. I think I will hold off on the radiator until I see a problem. I am mostly stock so may not have any issues.
Did you try removing the armor to see if that made a difference? I could imagine less fluid would mean the existing fluid would be circulated more and be less exposed to the heat trapped under-body.
Yes on armor. It helped a bit. That’s where I got the idea to drill holes in the armor.
Once holes drilled… I’d estimate it was close to the same as without armor…. But without armor had same issue… once heated up it stayed hot.
Sent from my iPhone using Tapatalk Pro
