Real Name: Leif
Real Name: Leif
FS: Set of 4 5th-gen Trail Premium wheels + 265/70R17 Blizzak tires, $700, Dolores CO
FS: Four 5th-gen OEM Trail Premium wheels with almost-new Blizzak winter tires; lug nuts incl
What: Four 5th gen OEM 4Runner Trail Premium wheels, each with mounted and balanced Blizzak DM-V2 265/70R17 winter tires. Full set (24) matched wheel lug nuts (4 with locks) plus lug nut key (use your 21mm socket). These fit several generations (I had them on my '99).
Condition: Tires: used and very clean, edgy; 4,378 documented miles. Date-matched set, all with 2818 date code. Wheels: excellent condition with only minor wear, mainly from rotations.
Price: $700
If you're within 50 miles and confirm you want these, I can meet you at a convenient halfway point on the map. Local sales obviously preferred; if you're not local, we'll need to discuss shipping, which will likely be cost-prohibitive.
'99 'Highlander' 4R SR5 5VZ-FE | 5-spd | LED lighting | TBU | 265-75R17 Duratrac stuffed after some pinch-weld convincing
'95 Xtra cab 5VZ-FE swap 5-spd | 33x10.50-15 BFG AT/KOs | 4" Superlift | ARB rear locker | OME torsion bars | Total Chaos idler arm & uniball | Smittybilt bumpers | Sportsman topper | Aisin manual hubs | K&N | Dual Optimas | Extended diff breathers | Bilstein 5100s | De-striped | Hella pencil-beams
