Originally Posted by thezentree
I have budbuilt front and belly skids. They are tough as hell and mostly fit, but the bends aren't great and so the skids don't go together like they should. The belly skid is supposed to hook over the top of the back of the front skid so they can be removed independently of each other, but the bends are wrong on mine in that area, so the belly skid has to be bolted to the bottom of the front skid. This means I've got to take both of those skids off to change my oil.
Also, I have like 5/8" worth of washers as spacers between the belly skid and frame, because otherwise the skid hits the transfer case before the frame. I think these were designed around a Tacoma and are close enough that they sell them as universal 4Runner skids.
Bottom line, they work, but they don't go together as easily as they should and are a pain in the ass to get to fit right. That said, they are one of the less expensive options and had fast shipping, so there's that.
Forgot about this. My Shrockworks transfer skid also had to be spaced away from the frame to keep the transfer case from hitting it and causing noises. Took me awhile to figure out that noise.
The front skid also contacts the cross member the steering rack mounts to. Haven't found a way to fix this one so I just live with the small noise it makes when turning and flexing, like leaving a driveway. Could just be worn body mounts allowing too much movement or something like that I suppose.
2008 Toyota 4Runner Limited 4x4 - Salsa Red, DD, Mostly Stock, 89k miles
2001 Toyota 4Runner SR5 4x4 - Not Stock, Lifted, Armored, 291k miles
1987 Toyota Supra N/A - Stock, 2nd Owner, 92k miles
