I'll have to check when i get home, but I had it at Max when I was done. Tight lid, the whole thing.
I use a vacuum bleeder so I always have fresh fluid pouring in as I bleed.
One thing I've always struggled with was a good bleeding flow in the rear driver wheel. For whatever reason I never get more than a trickle out of that one vs the strong flow from the others. I'll sit there bleeding it for 5 minutes and no improvement. But that's happened before so this can't be that issue. And I do the FSM order of rear passenger, rear driver, front passenger, front driver.
