Real Name: Skip
Real Name: Skip
Just another thought, you may want to also try another OBD2 scanner to rule out that the issue isn't with the scammer you're trying now.
Also if the second scanner has the same issue, you might want to check the connector to the ECU to make sure there's no bent pins, etc. since it was replaced.
2004 Limited V8
