Make sure to replace your diff breather, or at least pull it and test by blowing through it. A bad breather can blow oil through the seal. I've been using dino oil in the rear diff since I did mine instead if synthetic I had been using. The dino oil seemed to fix the slight leak from the half botched press work the axle shop I took the half shafts to. Their first attempt was totally botched, wasn't going to be a third attempt. It's been ok with Lucas conventional 75W-90.
99 SR5 v6 4WD
11 SR5 v6 4WD
