Originally Posted by SnoRnR
Hi,
I’ve fitted the Switch Pro 9100 using the SDHQ dash mount for the control panel. The only thing I haven’t connected is the WHITE light trigger wire. Needs to be connected to a parking light signal or side marker. Is there anywhere I can connect it under the dash that doesn’t use an add a fuse?
I’ve already got various other items on add a fuses in the fuse panel. Running out of space down there.
If you are looking for just a trigger, how much draw is there?
I would think minimal for a trigger.
I know for a relay, draw is very minimal.
