Originally Posted by spartacus
Top mount spacers just raise the height by dropping the whole assembly down. Have to get longer bolts for the top mout. The draw back would be shock bottoming out with out longer bumpstops. Pre load spacers that go on the strut assembly will have the same effect as raising the bottom perch. There are a lot of folks running ome springs on the 2nd perch without any consequences. You can install your springs on the second perch and see how it handles. If you like it keep it if not then go a different route.
Those both are good ideas, I could only find one guy running omes and bilsteins on the second perch so I was skeptical. Thanks man
