View Single Post
Old 10-03-2021, 05:18 PM
FD7683 FD7683 is offline
FD7683 will become famous soon enough FD7683 will become famous soon enough
Originally Posted by 4runnerfiend View Post
What code are you getting for the check engine light?
Sounds like a vacuum lead possibly. Do a visual inspection for any cracked old hoses or loose or unattached lines.
I'm not sure on the code # but I know it was the o2 sensor code behind the cat. Hoses seem to be decent enough but I did find the intake hose near the throttle body cracked so I will replace it.
The IAC Valve was hella gunked up so cleaning it with TB Cleaner made it look and perform better and while I was there I also cleaned the TB itself. First inicial startup..... it ran normal but the idle drop was not present anymore so I hope it stays like that for good (the problem was intermittent).
2000 4Runner Limited 4x4 V6
