Real Name: Anthony
Real Name: Anthony
I’ve always bought 4” queen memory foam from Walmart and cut it to size. Use a sheet to cover and I also use the sheet to roll it up out of the way when needing the space.
To add, one big problem with an air mattress is that if it’s cold outside, you will never warm up, the air inside of the bed will never warm up to your body temp since it is a mass of non insulated air. as the night goes on it will actually get colder as the temp keeps dropping. When I would use an air mattress in the winter I would always regret it
