Originally Posted by 4r-4ever
i don't think it's a head gasket. how fast does it leak? check any area with pinkish crust. also, you can have your oil tested just to make sure it's not leaking inside. it could be leaking just behind your water pump. do you smell a foul odor inside the cabin?
It can drain the reservoir in no time. The weird thing is that there is always some coolant left in the bottom of the reservoir, which makes me believe it's not the head gasket and the leak is in the reservoir itself. But it only happens when it's driven.
