Originally Posted by FourRunner08
I don't know if this issue is the same one you're having... A few years ago, my rear suspension was squeaking terribly. It was actually the emergency brake line rubbing. They reseated it and it fixed it. It then happened on the other side and they fixed that... Have them check that.
Also, so far so good on my suspension. I've beat the heck out of mine rock crawling and off road. I'm in a TRD OR so not a pro... all stock. I'm hoping mine lasts. I really beat it up off road and am kind of surprised it's still functioning and not rattling or anything. That would drive me nuts.
Thanks. If replacing the rear shock doesn't fix it, I'll have them check that. In addition to all my suspension issues, I also had the dreaded 62mph steering wheel shake. Service advisor said balancing may not help so they tried cross rotating last time I was in. I also upped the tire pressure to 35psi. I had been running the recommended 32. That all seemed to help. But while they were test driving it, he said the tech felt a vibration in the brakes. Turns out my front rotors were warped. They turned them for me under warranty. I wanna keep the vehicle so I've since purchased a 5yr/100k Toyota platinum warranty through gamester's connection for an unbelievable price.
