Originally Posted by usdmej
had my 2020 KDSS lifted ~2.5" in front on jack stands this past weekend to do an oil change and i noticed that the sway bar was pivoted to the rear of the car so that it prevented my oil filter housing from being removed
it was blocking it by only a few mm, but i still had to grab a small prybar to pivot the swaybar out of the way to get my oil filter housing removed
anyone else run into this problem? could it be alignment related? i'm on SPC upper control arms using the recommended caster adjustment.
i should have taken a picture but i was in a hurry to complete the job
Found that problem at first oil change nine years ago. I guess Toyota still hasn't addressed that articular issue. You need to have the weight on the front tires to move the sway bar out of the way. Use ramps if you don't room to work underneath.
