Originally Posted by _Moose
So I don't feel any play, I think I'm going to try and get a video of the sound for you; Maybe you can better pin point it for me, but there is an Off-Road and 4x4 shop in my area that does proper alignments, balancing and so forth; I trusted them to put my RCI plates on, perhaps they can pin-point the issue.
Thing is, if its a CV Joint, and I have to replace the whole axle assembly, do you recommend OEM over another, or just stick with OEM?
You're saying clicking and squeaking. Which one? An alignment won't due any good with a suspension issue because you need to fix the problem first to be aligned right. They won't tell you this obviously want you to come back as many times as possible. I just replaced mine with A1 Cardones 120 a set. I caught my oems before they got bad. So they are My emergency trail paIr. The A1 Cardones Are good quality. The boots are the same material as the OEM And clamped on the same way. Smooth as a cloud. You can buy ten sets for the price of one OEM set. Not a hard job really.
