Originally Posted by phattyduck
Any chance you got the 3rz cable instead of the 5vz cable? I think the throttle body on the 3rz is a bit closer to the trans, so the cable would be shorter/different.
Otherwise, I'd say follow gamerfreak's advice - make sure the cable is following the most direct route from the trans up to the throttle body.
It’s the 5vz cable. Using the most direct route it’s too short
