Originally Posted by NEKExplorer
Plug 'n play they said, just take the harness and ecu from the donor they said, lol.
Thanks for the help, I'll keep after it.
It is, as long as you don't cross sub-generations! 96-98, 99-00, 01-02.
'99 and '98 are very different, wiring-wise. The '99 dash harness won't work with the rest of your truck, so unless you want to swap everything over to '99 spec (EVERYTHING!), your best bet is to find a '98 manual trans ECU and use your original '98 harness(es) and modify it for the MT.
Your transfer case control is also different between the Limited push-button case and the manual J-shift case on the MT, so you have to figure that one out too (keep the push-button case or swap to the J-shift and change out the electronics for that).
'99 4Runner SR5 Auto -
4WD swapped
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
