Originally Posted by mkrunnersd
Hi and nice ride and nice height with OMEs. I don't know if you are trying to lower height or same height as photo. I think you might need to use clip 5 minimum for about 2.5" lift per Bilstein Manual. If you have lowest clip setting it will only raise 1.38". Manual says V8 but I think it is similar to V6 depending if you have 600lbs or 650lbs coil spring.
Mike
Damn you got me thinking now. Yeah I lifted vehicle with OME springs. I was hoping to achieve this same height if not higher. The rear should be the same if I keep the rear OME 895.
