Originally Posted by originalg00kster
Damn you got me thinking now. Yeah I lifted vehicle with OME springs. I was hoping to achieve this same height if not higher. The rear should be the same if I keep the rear OME 895.
No problem. I liked the 6112s for the 2.5 diameter body but didn't realize the lift height was as aggressive as i wanted for my V8. Just didn't want you remove/reassemble to adjust height since it takes about an hour to adjust clips. Didn't want you to go through the pain I went thru.
Maybe the 650lbs springs may raise your V6 similar to the OMEs but I really don't know. Now I have an extra set of 600lbs springs in the garage after replacement.
Mike
