Originally Posted by IsacFignewton
Next up was the transmission mount. I chose to make it super simple and just weld a plate on the 2wd crossmember.
This may come back to bite you if you are want to use any off-the-shelf skid plates, but will be good if you ever go dual case (the crossmember will better support the second TC).
I still have a bit of the original 2WD frame horns left for the original crossmember...
'99 4Runner SR5 Auto -
4WD swapped
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
