OP out of curiosity, do you find that when you press the pedal when moving - take your foot off the pedal and then quickly press it again that it firms up?
If so, I have a nearly identical scenario going on with mine post TBU.
Just for documentation purposes, I went with the PowerStop KC2324 Z23 daily driver set up with Rotors, pads and calipers and StopTech 95044007 lines.
FWIW With this set up, the rotors were thicker (but same diameter as OE), the calipers larger (had to trim dust shield) and in turn the pads were larger as well. (I am not sure if this set up was 13WE or WL if I am being honest)
It stops. It will stop short. The shudder from the original warped rotors is now gone. But the OCD in me knows the pedal was firmer on the OG set up then it currently is, aside from quickly pressing the pedal the 2nd time when braking. That seems to have a more original feel for me.
That said, I am going to anxiously follow this.
I chalked it up to mine being an 01 with ABS and some people just seemed to have a different pedal after the TBU and dealt with it. I'd love to get to the bottom of it myself.
2001 SR5 | 275K+ | 3" Toytec Ultimate Coils | SPC UCA's | MotegiMR150 17x8.5 + Yoko Geo 295/70/R17 | 4Xi full drivetrain skids | OCD sway bar links F&R | Powerstop TBU | Opt OR Upper & Lower rear arms | MF Overland Exhaust | Retrofit LEDs | Vivid Lumen Fogs | Full Prinsu Rack | Front bumper retrofit/fat lip delete
1983 Pickup SR5 | 93K | LCE Street Headers | 31x10.5 BFG K02's, Full Desmog and Otherwise Original
1981 Pickup SR5 longbed | 142K |
